Configure Port Rate Limits
Configure broadcast, unknown unicast, and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
- On the Device Physical View, select a port or multiple ports.
- Select General.
- Select the Rate Limiting tab.
- In the row for the required traffic type, configure the bandwidth limit in AllowedRatePps.
- In the row for the required traffic type, select true for Enable.
- Select Apply.
Rate Limiting Field Descriptions
Use the data in the following table to use the Rate Limiting tab.
Name |
Description |
Index |
Displays the port number. |
TrafficType |
Displays the type of traffic being rate limited, either broadcast, unknown unicast, or multicast traffic. |
AllowedRatePps |
Specifies the allowed traffic rate limit for the port in packets per second (pps). 1–65535 configures the limit in packets for each second. The default is 25. |
Enable |
Enables or disables rate limiting. The default is false (no rate limit). |
